Just landed a 212 Interceptor, couple of questions
Postby Scoots » Fri Mar 03, 2017 7:10 pm
Hello all!
Love this boat, I can see the attraction. That being said I have a few questions that I think are specific to this boat..
1, This is the first boat Ive owned with off-shore style controls and boy it takes some getting used to. My controls are great but at running speed my throttle gradually reduces, I have to hold it in place this cant be normal?
2, Ive never owned a thru hull exhaust boat before but all Ive seen there is quite a bit of water coming out of the thru hull exists. I have captains choice and when in thru hull mode very little water comes out of the hull exhaust. Is this normal due to the captains choice? I could believe that if the case because a substantial amount comes out by the drive also while in that mode.
Thanks for your help.
Re: Just landed a 212 Interceptor, couple of questions
Postby buyfire » Sat Mar 04, 2017 12:03 pm
We'd need video while running on muffs to confirm you're getting enough flow, but I'm pretty sure that some of the cooling water still exits the prop with the exhaust open. You may need an adjustment to your throttle cable, the stick shouldn't move on it's own.
Postby Scoots » Sun Mar 05, 2017 12:46 pm
Probably wont run it again until all the cold weather breaks. Yeah I figured there is probably some adjustment, figured I'd ask in case someones dealt with it and could send me right to it. Thanks.
Postby GaMatt72 » Tue Apr 11, 2017 11:09 pm
The water is fine but yes the stick should not move on it's own.
2002 Interceptor 212
Volvo 5.7GI 300hp
Corsa Exhaust
GaMatt72
Occupation: Noneya
Postby Scoots » Thu Apr 13, 2017 10:30 pm
GaMatt72 wrote:The water is fine but yes the stick should not move on it's own.
Yeah, Im gonna work with it once were able to get on the water regularly. Thanks
