Dip Stick
Dip Stick
Postby jkwcfd » Fri Jul 18, 2014 2:03 pm
Hey all! Ok I don't know what happened but somehow my dipstick went missing. I have a 1997 interceptor 212 with 5.7 280 hp gsi. How can I get another one? I called local Volvo/penta parts dealer and they said no one carries it anymore. What can I do? I have a generic to fit over the tube. Thanks
John
2007 232 Interceptor
5.7 Merc MAG MPI
2004 Dodge ram 4x4
POPO/MEDIC/ CHAPLAIN
jkwcfd
Re: Dip Stick
Postby AndrewT » Fri Jul 18, 2014 7:48 pm
Re: Dip Stick
Postby HOT PURSUIT » Sat Jul 19, 2014 9:18 am
It's a GM 350 block. Go to a junk yard nearby, probably about a dollar :D
Re: Dip Stick
Postby AndrewT » Sat Jul 19, 2014 6:48 pm
HOT PURSUIT wrote:It's a GM 350 block. Go to a junk yard nearby, probably about a dollar :D
HP not as simple, the VP dipstick goes to the bottom of the tube and not the sump.
Normal small block dipstick may give you incorrect reading. Did you look at the links in my post?
Re: Dip Stick
Postby HOT PURSUIT » Sat Jul 19, 2014 7:32 pm
I stand correctd Andrew! Never looked just took for granted! :oops:
Re: Dip Stick
Postby AndrewT » Sun Jul 20, 2014 1:35 am
No worries HP , VP just have to be different, the dipstick tube has got a threaded end to screw on a pump to suck the oil out.
On mercruisers an oil drain tube pulls out through the bung?
Re: Dip Stick
Postby HOT PURSUIT » Sun Jul 20, 2014 8:32 am
On HP it does but many do not have the feature :(
Re: Dip Stick
Postby jkwcfd » Sun Jul 20, 2014 5:48 pm
Thanks Andrew I will check it out.
John
5.7 Merc MAG MPI
2004 Dodge ram 4x4
jkwcfd
