My new ride
Re: My new ride
Postby sdk » Sat May 17, 2014 8:53 pm
Congratulations!!
Re: My new ride
Postby tripvw » Wed May 21, 2014 2:37 pm
dschevy1 wrote:
Red Hot 232 wrote:Awesome!! :2cool: Thank you!! Hopefully by the end of the day I will have this ordered! :D Has anyone else installed an extra remote by the captains seat?
Yes I have and it's a pain in the ass but well worth it.
You will need to pull out your speaker and cup holder tray down by the floor (easier said than done) next snake and wiggle your arm in to loosen the pad screws so that you can reach all the way up to where the remote will be. use a hole saw to cut your remote hole and mount it. The "Y" cable can be run from the stereo under the front of your ski locker and through the other side (there is already a wire harness there that I zip tied the cable to, keeps it from sagging) then plug in reinstall everything and done.
^This is right. I got in a hurry didn't remove the speaker to loosen the pad so I winded up cracking the cup holder housing when I was putting it back in. no big deal though its barely noticeable. I used an air powered die grinder to cut my hole, made it pretty easy. You should be able to do the whole job in about an hour though.
07 212 Interceptor
10 F150 FX4 Screw
tripvw
Re: My new ride
Postby tripvw » Wed May 21, 2014 2:40 pm
my 2003 212 was rated for 10 people, this new boat is only rated for 7, however this new one feels much more stable with a load on it. I wonder what the deal is with that?
07 212 Interceptor
10 F150 FX4 Screw
tripvw
Re: My new ride
Postby AndrewT » Wed May 21, 2014 8:51 pm
Big block weight. Depends how heavy the crew is :)
Re: My new ride
Postby buyfire » Thu May 22, 2014 10:40 am
tripvw wrote:my 2003 212 was rated for 10 people, this new boat is only rated for 7, however this new one feels much more stable with a load on it. I wonder what the deal is with that?
My 2005 212 was rated for 9 people with the 5.0 MPI. My 2006 232 was rated for........... 8 with a 496MAG. I know the 496 added weight but, believe the Coast Guard regs for load must have changed around that time because I've spoken to others with big block 2004-05 232's with 10 people capacity.
Re: My new ride
Postby tripvw » Wed May 28, 2014 10:27 am
Yeah my old boat had same engine was the same length and all just rated for three more people. It's not a huge deal I just keep enough life jackets for ten people and if the DNR wants to give me a ticket for that he was probably going to find something to aggravate me about anyway. :hammer:
07 212 Interceptor
10 F150 FX4 Screw
tripvw
Re: My new ride
Postby tripvw » Wed May 28, 2014 10:32 am
I did think about having my local sign shop do some work on my capacity plate to make it read 10. I'm sure that's against some kind of federal law. Lol
07 212 Interceptor
10 F150 FX4 Screw
tripvw
Re: My new ride
Postby buyfire » Wed May 28, 2014 1:50 pm
tripvw wrote:I did think about having my local sign shop do some work on my capacity plate to make it read 10. I'm sure that's against some kind of federal law. Lol
Yeah, I nearly did the same thing with my 232. You can buy reproduction capacity plates online, but I don't remember the site.
Re: My new ride
Postby keyte » Wed May 28, 2014 4:11 pm
I believe you have to have the registration with you at all times and I am pretty sure mine has the capacity of 8 on it. However if you do the math of (Number of people = vessel length (ft.) x vessel width (ft.) ÷ 15) my 232 would not be rated for 8 more like 12. I would love to get to capacity of 9 since we have 3 kids and most of our friends have a couple also.
Here is one site to get a new sticker:
http://garzonstudio.com/boat/capacity-decal.html
'07 232 Interceptor
keyte
Re: My new ride
Postby m_snow » Thu May 29, 2014 7:35 pm
The capacity is pretty much determined by the factory. Under which, the US regs have their complex formula which results in a final weight capacity. That capacity may be more than what the factory will put on the placard. (You know, liability worries and such.) Now, with a weight limit in mind. An example for the placard may be:
Option 1 -
11 PERSONS or 1,554 lb.
1,554 lb. persons and gear
Option 2 -
6 PERSONS or 814 lb.
Option 3 -
Between 814 and 1,554 lb. persons and gear
ie.
6 persons or 814 lb.
1014 lb. persons and gear (a lesser still weight allotment)
Re: My new ride
Postby tripvw » Tue Mar 03, 2015 6:07 pm
AndrewT wrote:Need this one here: Kenwood Ca-Y107Mr Y-Cable
Just Google it :D
I bought this one last year and it doesn't work. I think its for the newer marine stereo. does anyone know where to find the Y cable for the stereo I have (pictured in the original photos) its a kenwood kts 300mr. I've googled my self half to death looking for it.
07 212 Interceptor
10 F150 FX4 Screw
tripvw
