232 roll in turn
232 roll in turn
Postby chambers1517 » Mon Mar 31, 2014 4:33 pm
My last boat was a Caravelle 207. It was a nice boat but I always wanted an Interceptor. I bought a 232 in the winter. Yesterday was the first time I have took it out. It has dual batteries. I noticed when going into a right turn, the boat leaned hard. When going into a left turn there was not much lean. If I stood in the center of the boat while sitting still there was no lean. I thought maybe with myself and 2 batteries on the same side, that could be why. I was by myself. Is this normal for an Interceptor? I don't remember the 207 feeling this way.
chambers1517
Re: 232 roll in turn
Postby AndrewT » Mon Mar 31, 2014 5:23 pm
I've got a 212 with only a single battery, mine seems to lean more when turning left, she almost seems vertical to the water.
I think there were couple of posts on the issue and trim tabs were way to go.
Postby buyfire » Tue Apr 01, 2014 2:14 pm
Prop torque should make the boat lean in noticeably more to Port (left). Unless you've got a Bravo 3 drive. Or, you're in Australia. Because, you know, everything is backward down there.
Postby tripvw » Tue Apr 01, 2014 11:21 pm
Interceptors lean pretty hard on turns. I feel like I could touch the windshield to the water at times if I wanted to.
07 212 Interceptor
10 F150 FX4 Screw
tripvw
Postby AndrewT » Tue Apr 01, 2014 11:31 pm
buyfire wrote:Prop torque should make the boat lean in noticeably more to Port (left). Unless you've got a Bravo 3 drive. Or, you're in Australia. Because, you know, everything is backward down there.
Good one buyfire :D I'll have to send to you one of those 10 feet long tiger snakes :mrgreen:
Postby iammarcuse » Thu Apr 03, 2014 2:28 pm
chambers1517 wrote: I thought maybe with myself and 2 batteries on the same side, that could be why. I was by myself.
Yup, put another passenger in and it will be the same both directions. I noticed the lean the first time i ran my 232 as well. Now I never really think about it. Although I sometimes I do have to ask my passengers to move around to get the boat more level when under way.
Postby HOT PURSUIT » Thu Apr 03, 2014 11:45 pm
Yep! Add throttle to prevent it. Sure makes the first time riders peon their eyes and grab for a hold on something though :D
Postby Swerve » Fri Apr 04, 2014 3:04 am
And a drop bear
Postby buyfire » Fri Apr 04, 2014 10:23 am
And a drop bear
I threw that comment in as payback for your posts describing what warm weather you've been having. :lol:
And what the hell is a drop bear???
Postby HOT PURSUIT » Fri Apr 04, 2014 10:42 am
I think he means beer! Prolly spell it differently down under :)
Postby AndrewT » Fri Apr 04, 2014 6:21 pm
I think Swerve will have to explain what he means.
Couple of cases if beer could help with the lean. :D
Postby Swerve » Sun Apr 06, 2014 8:40 pm
Drop BEAR is correct
http://youtu.be/ULEQpUY_crc
Postby HOT PURSUIT » Sun Apr 06, 2014 9:21 pm
Well I'll BE Swerve! What's us Yankees know :lol:
Postby AndrewT » Mon Apr 07, 2014 9:03 am
somehow I missed that one! I don't drink rum :)
