2006 Interceptor 232 Radio Removal
Re: 2006 Interceptor 232 Radio Removal
Postby iammarcuse » Sun May 11, 2014 10:15 pm
There is actually a super easy way to get it out. Remove the face plate and the grey bezel. Instead of trying to slide the radio out. Put a thin screwdriver in each side to release the metal catch and push the radio in. It will slide right in.
When I replaced it I left the strap unattached. It seems plenty secure without it.
Postby dsm1212 » Mon May 12, 2014 12:40 pm
I'm not sure what you are suggesting. I don't see how "push the radio in" and "it will slide right in" can get the radio out :-). Is there a way for the innards to come out of the case or something? I had no problem putting the radio back in. I agree the bar probably isn't necessary.
steve
dsm1212
Postby iammarcuse » Mon May 12, 2014 1:11 pm
You can't pull it out because the step prevents it. You instead push it in and then reach in the opening and undo the screw on the strap. Then just pull the radio out the raw opening once you have removed the plastic molding. I just did it. Took about one minute. Took another one minute to put in new radio. Easy weezie.
Postby dsm1212 » Tue May 13, 2014 7:54 pm
Cool, got it. I'll try that next time. I didn't see how the face plate would come completely off but from what you are saying there must be some latches on the sides. thanks
steve
dsm1212
Postby 2006207 » Wed Jul 02, 2014 5:08 pm
Did you get your radio removed? I have the same issue with my 207.
2006207
Occupation: Retired
