4.3 Mercu Crusier in a 2008 196 LS
Postby Fredcollett » Sun Jan 22, 2017 10:31 am
Has anybody found a solution to the Dieseling problem after you shut off the key in the 4.3 engine ??
After a long run or after I tow the kids on a tube the engine will diesel when shut off,
apparently this problem has been around for several years
I have tried fuel additive , high octane gasoline, adjusting the idling , None seems to make a big difference
if I let the engine idle for 2 or 3 minutes, then it will shut off an not diesel
Fred
Fredcollett
Occupation: Equipment manager
Re: 4.3 Mercu Crusier in a 2008 196 LS
Postby youmansjason01 » Sun Jan 22, 2017 9:54 pm
Many years ago, I owned a 1997 Four Winns with a Volvo Penta 4.3 GL (carburetor version, not fuel injected) and it had the same problem. It was very frustrating because the engine ran great in all other respects.
Unfortunately, the only semi-cure I could find was the combination of running Premium Unleaded gas (93 octane) and after a hard run, letting it idle for a couple of minutes before shutting it off.
