Ski locker drainage problem
Postby whtevr » Mon Jun 19, 2006 9:57 am
I just bought a used '05 187 LS and really cleaned it good for the first time this weekend. I noticed that the water that ran into the ski locker did not drain. Is the water supposed to drain to the motor compartment to be either bilged out or to be drained thru the main drain plug? Evidently this drain is clogged by something, does anybody have a suggestion on how to clear that clog? This is my first boat and I do not want to cause any damage. Thanks for any help provided!
whtevr
Re: Ski locker drainage problem
Postby devillar » Mon Jun 19, 2006 1:05 pm
drano?
whtevr wrote:I just bought a used '05 187 LS and really cleaned it good for the first time this weekend. I noticed that the water that ran into the ski locker did not drain. Is the water supposed to drain to the motor compartment to be either bilged out or to be drained thru the main drain plug? Evidently this drain is clogged by something, does anybody have a suggestion on how to clear that clog? This is my first boat and I do not want to cause any damage. Thanks for any help provided!
No Longer a Boat Owner: 2004 207LS/Volvo Penta 5.0L/Dual Batteries/SS Prop/Binimi Top/Swim Platform/Marine Com. radio/stereo w dual remotes/Depth finder/snap in & out carpet
Toyota Sequoia SR5 2004
devillar
Postby lcusick » Tue Jun 20, 2006 2:46 pm
I have the same problem with my '05 207SL. Don't know a good way to fix it or where it is supposed to drain.
lcusick
Postby buyfire » Tue Jun 20, 2006 4:03 pm
is the drain not just a hole between the low point in the ski locker and the bilge? if not, i'll bet it would be easy enough to make a hole. :lol:
Postby whtevr » Tue Jun 20, 2006 4:16 pm
I believe it is a slight clog because some of the water is verrrry slowly draining out. I think I am going to try sticking my hose end sprayer into the hole and forcing the water out. I will let you know what I figure out. I am not too keen on making any "new" holes in my boat. :lol:
whtevr
Postby Chappy » Tue Jun 20, 2006 7:23 pm
I don't think that there is anything between the ski locker and the bilge that you could harm, so couldn't you use a rod of some sort to push through the existing hole? My boat isn't stored at my house so I can't look. Just an idea.
06 Caravelle 207LS, 5.7 Volvo Gi 280hp, 19p SS Enertia Prop, Factory tower, Swim platform, 600W system with 10" sub, Black band hull.
Pulling with a 2011 Texas Edition Silverado Crew Cab 4x4
2008 Mazda CX9 Grand Touring
Chappy
Postby whtevr » Wed Jun 21, 2006 8:23 am
I tried using a electrical fish tape, but i believe the drain line has an elbow in it and I can't get the fish tape to bend with the elbow. I should be taking the boat home today or tomorrow and will try the hose. If that doesn't work, I will try my shop vac, if that doesn't work I think I will be calling the dealer.
whtevr
Postby dr5274 » Thu Aug 31, 2006 12:28 am
any resolution to this?
I just picked up my 237LS, and the ski locker seems to be holding water, too. There was/is quite a bit of scrap stuff in the bottom, so that may be causing a clog. It sure seems funny that dealers don't clean this out as part of the make-ready :evil:
dr5274
Postby whtevr » Fri Sep 01, 2006 11:28 am
I was never able to get it to drain the way I thought it should. It still drains very slow. The dealer was of no real help. I just leave the bow as high as I can get it and let drain that way over several days.
whtevr
Postby dr5274 » Fri Sep 01, 2006 11:54 am
so the vac didn't help?
maybe there's a way to get the boat high in the rear, and then pour some water into the bilge area. hopefully it could wash the trash back to the ski locker?????
dr5274
Postby Holeshot » Mon Jun 09, 2014 7:03 pm
Has anybody figured this out yet?
Matt
Tampa, FL
Caravelle 237LS - 350 Mag MPI Bravo
Holeshot
Occupation: Auto Broker
Postby m_snow » Mon Jun 09, 2014 9:08 pm
Try a pressure washer?
Postby rward182 » Tue Jun 10, 2014 8:38 am
While cleaning up my '07 187, I noticed that the ski locker wasn't draining right. I took the drain cover off in the locker and sprayed water forward from the engine compartment and the round scrap from where the factory cut a hole in the deck came out of the drain. I was able to wash it far enough forward to grab it. Now the locker drains correctly.
Postby m_snow » Fri Jun 20, 2014 7:00 pm
Woohoo! Dang leftover parts...
Postby MattOso » Wed Jul 02, 2014 8:46 am
This is crazy everyone seems to have brought this issue up because I just have been noticing my 232 2005 doing the same thing. Guess im going scrap hunting in my boat!! lol
OSO
2005 232 350Mag
Lake Michigan
MattOso
Occupation: Army Technician
