Radio power line...
Radio power line...
Postby msbendts » Tue Jul 23, 2013 10:12 pm
I'm noticing that my radio is powered much like a radio in the car...when the key is in the OFF position (center), the radio is also powered off. This is probably designed to keep from accidentally draining the battery, but is annoying to have the music stop playing and then restart playing when changing the key position.
Has anyone rewired their radio so that:
1) power feed is always on? If so, what did you tap into?
2) power feed is controlled by ACC switch? (is ACC switch on dash not affected by key on/off/acc position?)
3) any other means?
Just curious if others have been annoyed and changed their power feed...
msbendts
Re: Radio power line...
Postby 02blkws6 » Fri Jul 26, 2013 11:15 pm
Mine is hard wired into the switch panel and always has power with key off.
02blkws6
Postby dancaravelle267 » Wed Jul 31, 2013 1:50 pm
My stereo is wired so that if I turn the ignition key one click left of straight up and down the stereo will be powered?
Postby AndrewT » Wed Jul 31, 2013 6:16 pm
dancaravelle267 wrote:My stereo is wired so that if I turn the ignition key one click left of straight up and down the stereo will be powered?
Mine is the same.
Postby dancaravelle267 » Tue Aug 06, 2013 4:05 pm
My crownline was wired hot. I didn't wire it so I am not sure where it wired to but I was always worried I left it on. I didn't have a batt switch or dual batts.
Postby m_snow » Sat Aug 17, 2013 1:17 pm
Put a big stereo capacitor on the power cables as close to the radio as conveniently possible. Not only will it power the radio between key switching, it will help the overall sound. :2cool:
GL!
Postby dancaravelle267 » Thu Aug 22, 2013 4:35 pm
m_snow wrote:Put a big stereo capacitor on the power cables as close to the radio as conveniently possible. Not only will it power the radio between key switching, it will help the overall sound. :2cool:
GL!
That's a good idea
