2003 217 5.0L New Member
Post pictures of your boat here. Be sure to let us know what we are looking at.
Re: 2003 217 5.0L New Member
Postby Razorback217 » Mon Apr 25, 2016 10:05 pm
I did remove some of the stock graphics/ decals. Some were scratched. I am getting used to the look of them without.
Razorback217
Postby Razorback217 » Mon Apr 25, 2016 10:19 pm
Question: I have had my 2003 217 for a year now and I need to address the fact that it doesn't have a kill switch. I have friends with older and newer boats that have this feature. Am I missing something? Was this an item that was removed and bypassed or something that did not come with this model? I have added some pic from a few different angles and as you can see no kill switch. I have seen them on the throttle and others that are mounted near the ignition switch. Everything works as it should.
Razorback217
Postby HOT PURSUIT » Tue Apr 26, 2016 8:45 am
I believe that something is amiss! Get a better photo of the shifter from straight on so we can see the entire face of the unit. I believe the kill switch is a Fed requirement and I have never seen one that can be removed.
Postby buyfire » Tue Apr 26, 2016 11:13 am
Looks like someone bypassed it. The little button at the front edge of the throttle mounting plate is where your lanyard should go. If you grab the button, it should pull out about 1/4". The engine should crank but not start without it pulled out.
Postby HOT PURSUIT » Tue Apr 26, 2016 2:37 pm
Good eye BUYFIRE I shoulda taken longer to look :mrgreen:
Postby Razorback217 » Tue Apr 26, 2016 10:35 pm
This is what I found in the manual. I am still searching........
throttle image.JPG (38.26 KiB) Viewed 527 times
Razorback217
Postby buyfire » Wed Apr 27, 2016 10:17 am
I guess I may not be as familiar with the Volvo setup as I thought. On the Mercruiser control, that is the location for the Lanyard. The "Beach" catch, as VP calls it, is located in the center of the control lever mount on a Mercruiser.
Return to Show Us Your Boat
