1971 17' Caravelle (Whip Ray)
Post pictures of your boat here. Be sure to let us know what we are looking at.
Re: 1971 17' Caravelle (Barracuda)
Postby muskey47 » Tue Apr 12, 2016 6:45 am
Started getting the stringer measure/cut while waiting for the weather to warm up.
Tried to transfer the slope of the boat by a sophisticated measuring tool that i found on craigslist...it worked pretty well!
It came with an equally sophisticated check system for the measurements...
Only had to trim it down 12 times!!
The weather finally allowed me to get some glass work done!
Got the transom fillets done and got it tabbed in.
transom completely glassed in!
muskey47
Occupation: Simulation Engineer
Re: 1971 17' Caravelle (Whip Ray)
Postby HOT PURSUIT » Tue Apr 12, 2016 6:53 pm
WOW! Youy are DA MAN! :D
Postby muskey47 » Wed Apr 27, 2016 11:44 am
A few updates. NOt too much in the way of progress since my other boat sale fell through (one bad cylinder on one engine...so now, i have that to do too!)
Stringers. Bedding stringers in is a very messy job...LOL
Just need to sand them down and glass them in, then i'm ready to cut the deck and install!!
So excited to be able to sand on a floor!!
muskey47
Postby HOT PURSUIT » Wed Apr 27, 2016 2:25 pm
WOW :shock:
Postby muskey47 » Fri May 13, 2016 9:23 am
Just a quick update...
Stringers are glassed in. Floor is cut.
glue and screw next!
muskey47
Postby muskey47 » Tue Jun 14, 2016 7:42 am
Got some more work done on it...getting very close!
Even got to drop it in at the launch to check to make sure no leaks coming from the new drain tube!
I hope to have it running and in the water by the 4th of July :)
muskey47
Postby buyfire » Tue Jun 14, 2016 10:52 am
Coming along nicely. Man, that looks like a lot of work though.
Postby muskey47 » Tue Jun 21, 2016 5:54 am
Starting to see the light at the end of the tunnel.
Installed new rub rail, gas filler hose and vent hose.
Started putting her back together. going to need to find some trim pieces soon!
Also dropped her in at the launch just to make sure no leaks from the new drain tube!
muskey47
Postby HOT PURSUIT » Tue Jun 21, 2016 6:32 pm
WOW!
Postby Irie Mon » Wed Jun 29, 2016 4:18 pm
That is one heck of a project. It is looking good. Are you going to make it into the water this weekend.
Postby muskey47 » Thu Jun 30, 2016 1:40 pm
i have to install the new steering cable and test the engine one more time, but i'm hoping to put it in and give it a good shake down this weekend!
muskey47
Postby jfair32 » Thu Jun 30, 2016 3:07 pm
Drum roll please.....
Postby rward182 » Fri Jul 01, 2016 8:09 am
Looks great!
Postby muskey47 » Wed Jul 06, 2016 11:15 am
Motor is attached, steering cable is attached.
New Water pump is ordered....lol
She's pretty close to the first sea test!
muskey47
Postby muskey47 » Tue Jul 26, 2016 9:47 am
well,
She floats! and Runs! (kind of)
a little issue with it stalling at idle speed. I'm sure it has something to do with the fuel pump/fuel lines
but test #1 passed!
still have plenty of work to do, but at least i can buzz around, drink a beer, then work on it :beer:
muskey47
PreviousNext
Return to Show Us Your Boat
