Turbo lube hub!!
Turbo lube hub!!
Postby shadillac » Mon Aug 11, 2014 2:08 pm
Anybody have any idea which Turbo hub kit fits the 2007 Tennessee trailer for the 232 interceptor(is it the 1350# or the 1750# kit) I called tiedown themselves but they just wanted me to spend 280 bucks on the new vortex hub kit. Im thinking the 1750 but not for sure and can't really find any info on them? Any help would be great!!
shadillac
Re: Turbo lube hub!!
Postby AndrewT » Mon Aug 11, 2014 6:50 pm
I'm pretty sure they would be the 1750 lb axles with 1.98" bearing protectors.What are you going to to with the hubs on the axle with brakes?
I inspect mine every 12 months, repack the grease if required and replace the grease seals.I have replaced the bearings last year and the inside of the hubs looked like its been done a week ago after 12 months of use.
We launch into the salt water a few times a year so I need to be extra careful.I change the brake fluid and check the brakes at the same time. I would probably save your money and just maintained the existing hubs.
Just my 2C worth.
Postby shadillac » Wed Aug 20, 2014 2:47 pm
Thanks for the info Andrew. Tie down finally returned a message and said it the 81141 kit. So i ordered 4 of them and replacing them all at once.
shadillac
