interceptor wot alarm.
Postby chambers1517 » Thu Jul 03, 2014 4:23 pm
I have an 08 Interceptor 232 with the 350 mag. When I run at wot I get a high pitched alarm. Sounds like the depth finder alarm but it only happens at high rpm. I can slow all the way to idle and the alarm continues to sound until I shift to neutral. All gauges look fine. Gear lube is ok also. Any ideas? Rpm never goes above 5000.
chambers1517
Re: interceptor wot alarm.
Postby AndrewT » Thu Jul 03, 2014 5:59 pm
She's not over reving? What pitch prop are you running ?
Postby chambers1517 » Thu Jul 03, 2014 6:53 pm
II am running a 21p vengance. Tack never reads above 5000. One weird thing I noticed today is I get 5000 rpm at wide open but it takes about 5 clicks back on the throttle for the rpm to start dropping. The tack seems to read smoothly through the entire range.
chambers1517
Postby AndrewT » Fri Jul 04, 2014 1:40 am
Has this prop got a rubber hub? It may be slipping causing the motor to over rev?
One you back off it stops slipping?
Postby HOT PURSUIT » Fri Jul 04, 2014 9:15 am
Strange! BUT, if it is truly an alarm I would NOT run her at WOT until I figured out what it is Sir. Is it a constant alarm or beeping? In dash depth soumder on HP is junk and goes off every once in awhile.
Postby chambers1517 » Fri Jul 04, 2014 10:17 am
It is a constant alarm. Even when I slow down to idle it constantly sounds. I have to shift to neutral to make it stop. Oil pressure And everything is normal. I can run 4800 rpm with no issue but at 5000 the alarm sound and won't stop until I hift to neutral. I thought 5000 was ok on these engines. Does the high rev alarm require a neutral to reset. There is nothing to tell what exactly the alarm is.
chambers1517
Postby HOT PURSUIT » Fri Jul 04, 2014 11:53 am
HEading to the water, but, if you hit the rev limiter the engine should kick in and out as it knocks the RPMs back. Check your book for the sound of the alarm, should surely tell you what it is. OP and Temp OK wierd. Outdrive full? That has an alarm as well. OUtside those 3 things I don't think anything else has an alarm. Good Luck!!
Postby MattOso » Fri Jul 04, 2014 12:41 pm
OK, so I have an 05 with the 350 MAG. I also have the same alarm go off that sounds like the depth finder. On my boat its the low oil pressure alarm going off. The only way I've fixed it is to make sure the oil is always toped off as some burns on mine. Not much burn but with a small oil reservoir, mine will almost always go off if she's the slightest bit low. Might be an avenue to look down?
OSO
2005 232 350Mag
Lake Michigan
MattOso
Occupation: Army Technician
Postby chambers1517 » Fri Jul 04, 2014 1:47 pm
We are staying on a floating cottage on Lake Norris. I checked the book and it isaid. Over rev or drive lube level. Drive lube is at min so that may be it. Went to marina and drive oil was 9 bucks for 8 oz. Ill try that next. Thanks guys. I noticed as the revs increase the drive oil level goes down some.
chambers1517
Postby AndrewT » Fri Jul 04, 2014 6:49 pm
More info on Mercruiser alarms:
Engine Guardian System ALARM SUMMARY
General Description
Engine Guardian is the focal point of the self-diagnostic strategy on these engines. It helps
protect the engine from possible damage that could result from several faulty conditions.
The system monitors the sensors incorporated on the engine and if a malfunction is
discovered, a fault description is stored in thePCMand available power is normally reduced.
By ensuring that engine output is at a low enough level, the engine is better protected from
thermally induced failures.
For example, if an open or short is found in any sensor, available power will be reduced to
90% of total, the AudioWarning System Alarmwill sound 2 beeps perminute (2 Bp/min) and
the Smartcraft gauges will display a warning lamp. In a seawater pump pressure low
condition, the maximum rpm will vary with the pressure and temperature of the engine and
could be limited to idle in extreme cases of overheating, a constant beep will sound and
IMPORTANT: Engine Guardian cannot guarantee that engine damage will not occur
when adverse operating conditions are encountered. Engine Guardian is designed
to warn the operator of an adverse condition and to reduce power by limiting rpm in
an attempt to reduce possible engine damage. The boat operator is ultimately
responsible for proper engine operation.
SERVICE MANUAL NUMBER 36 GENERAL INFORMATION
90-864573 FEBRUARY 2002 Page 1A-25
Warning Chart
The engine warning system incorporates an audio alarm and, if installed, Smartcraft
Gauges System. When the key switch is turned to the ON position, the audio alarm will
momentarily activate to test thewarning system. The alarm should sound once if the system
is operable. This table is a guick guide, showingwhat warning output will accompany a fault.
Fault Smartcraft Gauges Audio Alarm Available Power Description
ECT CKT HI Yes 2 Bp/min 90% Open
ECT CKT LO Yes 2 Bp/min 90% Short
ECT Coolant Overheat Yes Constant 6 - 100 % Overheat condition
EST 1 Open 1 Yes 2 Bp/min 100% Coil harness wire open
EST 1 Short 1 Yes 2 Bp/min 100% Coil harness wire short
Fuel Injector 1-7-4-6 Open Yes 2 Bp/min 100% Fuel injector wire open
Fuel Injector 3-5-2-8 Open Yes 2 Bp/min 100% Fuel injector wire open
Guardian Strategy Yes Constant 0% - 100% Protection Strategy
IAC Output LO/HI 2 Yes 2 Bp/min 90% Open
Knock Sensor 1 Lo Yes 2 Bp/min 90% Open
Knock Sensor 1 Hi Yes 2 Bp/min 90% Short
Low Drive Lube Strategy Yes Constant 100% Low oil in sterndrive
Low Oil Pressure Strategy Yes Constant 0 - 100% Low oil pressure strategy
NOTE: If any 5v sensor becomes shorted to ground the engine will not start. If the engine is operating when the short occurs the engine may stop operating and will not start.
NOTE: 1 GM EFI ignition system failure open or shorted, driver will flag EST 1 fault.
NOTE: 2 TPS must see 5% throttle then back to 0% to flag IAC fault.
NOTE: 3 2-wire sensor open will read sensor Hi on scan tool.
NOTE: 4VDC PWR Low - if shorted or no voltage engine will not start; if VDC PWR voltage falls velow 22 volts will set sensor faults.
NOTE: 5 Shift Switch - will activate code when engine rpm are above 3500 rpm and 40%
load.
GENERAL INFORMATION SERVICE MANUAL NUMBER 36
Page 1A-26 90-864573 FEBRUARY 2002
Warning Chart (continued)
Main Power Relay Output Yes No N/A Engine will not start
Main Power Relay Backfeed Yes No N/A Engine will not start
MAP Sensor 1 Input High Yes 2 Bp/min 90% High voltage or short
MAP Sensor 1 Input Low Yes 2 Bp/min 90% Open, no visual on
SC1000 Oil PSI CKT Hi Yes 2 Bp/min 90% Open, defaults to 50.7 psi
Oil PSI CKT Lo Yes 2 Bp/min 90% Short, defaults to 50.7 psi
Overspeed Yes Constant rpm limit Engine over rpm limit
Pitot CKT Hi No 100% Short or high voltage
Pitot CKT Lo No 100% Open
Sea Pump PSI Lo Yes Constant 6-100%
GuardStrat Sea Pump CKT Hi Yes 2 Bp/min 90% Open - 0 psi reading
Sea Pump CKT Lo Yes 2 Bp/min 90% Voltage high or short
Sea Water Temp No N/A Defaults to --31 degreesC
Fuel Level #1 No N/A Only if turned on
STB EMCT CKT Hi N/A N/A N/A N/A
STB EMCT CKT Lo N/A N/A N/A N/A
STB EMCT CKT Overheat N/A N/A N/A N/A
load.
90-864573 FEBRUARY 2002 Page 1A-27
Steer CKT Hi No 100% Short or high voltage
Steer CKT Lo No 100% Open
TPS1 CKT or Range Hi Yes 2 Bp/min 90% Short or high voltage
TPS1 CKT or Range Lo Yes 2 Bp/min 90% Open or low voltage
Trim CKT or Range Hi Yes No 100% Open or high voltage
Trim CKT or Range Lo Yes No 100% Short
5 VDC PWR Low 4 Yes 2 Bp/min 90% Short or low -
engine may not start
MAT Sensor Hi Yes 2 Bp/min 90% Open -default to --32
degrees F
MAT Sensor Lo Yes 2 Bp/min 90% Short -default to --32
degrees F
Shift Switch 5 Yes 2 Bp/min 90% Open Circuit
load.
Postby chambers1517 » Fri Jul 04, 2014 8:03 pm
So I took the boat out again after I filled the drive tank. I got up to 4000 rpm and the alarm came back on but as soon as I throttled back it went away. I ran awhile and slowly throttled up. I got all the way to 5000 with no more alarms. I ran about 10 mile between 3500 up to 5000 with no alarms. Ill try again tomorrow.
chambers1517
Postby buyfire » Sat Jul 05, 2014 10:19 am
So, did you top off your gear lube? And you also made sure to top off with the same color lube? The hi performance lube is a different color than the standard stuff. Do you trim your drive a bit higher at 5K RPM than the lower R's? That would explain why the alarm only went off at WOT. You could also get a constant alarm (no beep) at WOT if a heat exchanger is partially clogged with silt, rocks, etc.
Postby chambers1517 » Sat Jul 05, 2014 10:56 am
I think you may be right about trimming up more during high speed I Noticed I trimmed more as speed increased. That may explain why I was getting the alarm. I did topp off the drive.
chambers1517
