WTB. Stainless steel. 19 p. Or. 21 p. 4 blade prop
Postby Fredcollett » Sat Jul 30, 2016 10:56 am
Want to buy. A 4 blade. 19 pitch or 21 pitch. Stainless steel prop.
For a. 2008. Caravelle 196LS. 4.3 Mercury 190 hp 1.81 ratio. Aphla out drive
Currently running a 3blade alum prop. 14.5 x 21.
Fredcollett
Occupation: Equipment manager
Re: WTB. Stainless steel. 19 p. Or. 21 p. 4 blade prop
Postby youmansjason01 » Sat Jul 30, 2016 11:00 pm
Assuming your current prop puts you in the desired max RPM range, you will definitely need to reduce the pitch when going to a Stainless Steel prop and a 4 blade prop.
Usually, when going from Aluminum to SS, you need to reduce pitch by 1-2. Then, when going from 3 blade to 4 blade, you also need to drop 1-2 pitch. So, if you're planning to do both in switching to SS and going from 3 to 4 blades, you definitely need a 19p or possibly an 18p.
