Enertia Prop question
Postby pilotmike » Tue May 26, 2015 2:26 pm
Looking for a used Enertia prop on line and a noticed a couple of different part numbers for the 21 pitch. I have seen the #48-899003A46 & I have seen #48-899002. Is there a difference??
Mike V.
2001 232
350 mpi
Hot Pink, Hot Yellow, and Jade
Shes Loud and Proud
pilotmike
Re: Enertia Prop question
Postby m_snow » Tue May 26, 2015 7:08 pm
Probably the diameter. Nope, checked - it's RH and LH!
Postby pilotmike » Wed May 27, 2015 12:11 am
That's funny, both were labeled as left handed. Didn't really look though. These Bravos need a RH prop if I'm not mistaken.
Mike V.
2001 232
350 mpi
Shes Loud and Proud
pilotmike
Postby buyfire » Wed May 27, 2015 10:17 am
Yes, you'd need the RH. Unless you fancy the idea of going backward really fast!
Postby pilotmike » Wed May 27, 2015 10:53 am
Copy That!! Although fast is fun in any direction!
Mike V.
2001 232
350 mpi
Shes Loud and Proud
pilotmike
Postby buyfire » Thu May 28, 2015 10:15 am
pilotmike wrote:Copy That!! Although fast is fun in any direction!
True, but you'll notice your MPG will improve noticeably when you put the pointy end in front.
