Selecting the right prop
Postby 02blkws6 » Sat Apr 27, 2013 6:29 am
Volvo Penta SX-C1 1.66 outdrive with a 5.0FL/302 4bbl
current prop is 14.25x19 and spins 4900-5000rpm
suggested operating rpm 4200-4600
I'm considering a new prop and want to get it right. The ebay link is what I have in mind.
http://www.ebay.com/itm/VOLVO-SX-PLEASU ... fe&vxp=mtr
02blkws6
Postby Muncie6spd » Mon Apr 29, 2013 11:18 am
I run the Mercury High Five 14.25X21 on my 5.0 MPI, it's great! It does a much better job towing wakeboards and tubes than the 3 blade Turbo 14.5X21 stainless prop that came with the boat. I lost about 2-3 mph on top end but I very rarely run it full throttle. The boat will plane at 18 mph while towing my kids and grandkids on a wakeboard and I can tow the young ones at 12 mph on a wakeboard.
I also tow 3 or 4 tubes at a time at around 20 mph without difficulty while slinging them from side to side.
Since you're over revving with the 19 pitch a 21 pitch should get you down to the recommended RPM for your engine in my opinion.
Postby HOT PURSUIT » Tue Apr 30, 2013 10:03 am
Remember: about 200 Rs per pitch which drops you 400 on a 3 blade = about 4500. Also about 200 Rs for extra blade times 2 equals another 400 on a 5 blade down to 4100. Just rule of thumb, have never experimented with the 5 blade, only a 4.
A Merc Revolution 4 in a 20P may do you very well. Find a friend with different ones or go to deltaprop.com. They will let you try a prop then return it if not right for used to be $25 restock which is far better then having to sell it on ebay. Good luck and you will LEARN from your experience :lol:
HP[/b]
Postby youmansjason01 » Tue Apr 30, 2013 2:40 pm
Also, keep in mind that if you are changing from Aluminum to SS in the same pitch (19 pitch aluminum to 19 pitch SS), you will also see a 100-200 RPM drop.
Postby 02blkws6 » Wed May 01, 2013 10:04 am
19 pitch ss
I've been doing some research about 5 blade props and the reviews that I've read weren't very good.
I'll probably just go with a 3 blade 21 pitch ss.
Anyone that's tested multiple 3 blade ss props, which one has performed best? I'm looking for it to be my light load top speed prop..
02blkws6
Postby Muncie6spd » Wed May 01, 2013 12:54 pm
HOT PURSUIT wrote:Remember: about 200 Rs per pitch which drops you 400 on a 3 blade = about 4500. Also about 200 Rs for extra blade times 2 equals another 400 on a 5 blade down to 4100. Just rule of thumb, have never experimented with the 5 blade, only a 4.
HP[/b]
HP, actually I did not loose RPM when changing from 3 blade to 5 blade, if anything the RPM's went up a bit. The only thing I can attribute this to is 1/4" smaller diameter on the 5 blade.
Postby xcr-700 » Wed May 01, 2013 9:34 pm
02blkws6 wrote:19 pitch ss
Not sure what reviews you have read but almost everyone I know who has tried a 5 blade has had good things to say about them.
As for 3 blade props, unless top speed is your only concern then you should consider a 4 or 5 blade prop over a 3 blade. Top speed is the only thing 3 blade props do better and even then its a small advantage.
Modern 4 and 5 blade props are a big advantage over most 3 blade props.
It would be worth a bit more research before making a mistake.
Good Luck
Postby HOT PURSUIT » Wed May 01, 2013 9:35 pm
I often wondered if the diameter being smaller would have an effect and now I know. Thanks Mike :lol:
Postby HOT PURSUIT » Wed May 01, 2013 9:58 pm
If you are going to stay with a 3 blade 02blkws6 NOTHING can match the Merc ENERTIA in my humble opinion and those I have talked into trying it :lol:
