Testing out some props tomorrow
Postby K-Dubb » Fri Jul 20, 2012 7:27 pm
I will be testing a mirage plus 23p and a mirage plus 25p labbed tomorrow! Currently running a vengence 23p. Doing the testing program from bblades.
Can I use the hub kit I have on both of these props?
Any other gotchas? I'll let everyone know the results.
2004 232 caravelle interceptor, 496mag
K-Dubb
Postby Flyguy242BR » Fri Jul 20, 2012 8:59 pm
Yes you can use the same hub kit.
It should be the flo torq II part#835257Q1
I have a Mirage Plus 25p that is labbed and cupped, and I really like it...
Are both props labbed, or just the 25p?
EX-2006 Caravelle 242 LS
496 MAG Bravo 1, Captain's Call, & other "Optional Features."
Flyguy242BR
Postby K-Dubb » Fri Jul 20, 2012 11:01 pm
Flyguy242BR wrote:Yes you can use the same hub kit.
Just the 25p.
What is the torque rating on the prop nut?
K-Dubb
Postby Flyguy242BR » Fri Jul 20, 2012 11:31 pm
FYI: The MAX. rpm (WOT) for the 496MAG is 4400-4800; the 496HO is 4600-5000 at normal operating temperature which is 160 degress.
Per the Bravo 1 service manual, it's a minimum of 55lb-ft depending on if the flats of the prop nut lines up with your tabbed washer.
If you are at 55lb-ft and the flats on the prop nut don't line up with the tabs on the washer, tighen the nut until they do, do not loosen it....
Flyguy242BR
Postby K-Dubb » Fri Jul 20, 2012 11:48 pm
Flyguy242BR wrote:FYI: The MAX. rpm (WOT) for the 496MAG is 4400-4800; the 496HO is 4600-5000 at normal operating temperature which is 160 degress.
Thanks! I am at about 4950-5000 in 100* heat now.
K-Dubb
Postby Flyguy242BR » Sat Jul 21, 2012 8:29 am
I think you will like the 25p.
That is what I have, and my PRM's are around 4700...
Flyguy242BR
Postby buyfire » Sat Jul 21, 2012 10:14 am
i run avout 4900 RPM with a 25p ballistic. my 25P mirage gets me about 4850 RPM before she starts to air out. i'm interested to see what the labbed 25 does for you. what was it labbed for, top speed?
Postby K-Dubb » Sat Jul 21, 2012 2:17 pm
I am not sure what it was labbed for. Bblades just said another guy backed out on it.
Well I am not really happy with the speeds. I don't know if you guys are running in cooler weather or what.
DA was about 2500 *edit*, so not that great
Light chop.
I turned the 23 mirage at about 4850, which got me 61.
I turned the labbed 25p at about 4500ish, which got me 63.4
This is using the gps app on the iPhone. Not sure how accurate it is.
2 people, 2/3 gas.
I am not sure how you guys are running the speeds you do.
K-Dubb
Postby buyfire » Sat Jul 21, 2012 2:27 pm
DA for my area is generally between 650 to 800. you can also look for your best numbers in the morning, and when humidity is low. if you have a bowrider, put the bow cover on. i'm still waiting for that perfect test day when i don't have the whole family & lots of gas.
Postby K-Dubb » Sat Jul 21, 2012 2:42 pm
No bow cover. This was done at about 9:30, but DA was still 2500.
K-Dubb
Postby K-Dubb » Mon Jul 30, 2012 10:10 am
Sending the 25 labbed back to bblades. They are going to adjust the rake a little and send it back.
K-Dubb
Postby Flyguy242BR » Mon Jul 30, 2012 4:37 pm
K-Dubb wrote:Sending the 25 labbed back to bblades. They are going to adjust the rake a little and send it back.
Yes, you should be in the mid-upper 60's
Flyguy242BR
Postby K-Dubb » Thu Aug 30, 2012 12:03 am
Hit 64.4 today with the labbed 25. DA was 3200 so I would say that is pretty dang good!
K-Dubb
Postby buyfire » Thu Aug 30, 2012 10:10 am
that's pretty good. got to be happy with that.
