Best Prop for...
Re: Best Prop for...
Postby iammarcuse » Sat Sep 14, 2013 8:46 pm
In the meantime... boat away. You likely won't be turning the 23 past 4500 or the 21 past 4800, Just enjoy the boat and don't look at the tach until you get a new one. better yet, disconnect it so it doesn't distract you.
Postby HOT PURSUIT » Sun Sep 15, 2013 12:08 pm
MERC makes a 4 blade in aluminum called Black Max! FYI
Postby Johnny HotFoot » Sun Sep 22, 2013 8:43 am
I guess we have to disregard all previous information.... except for the top speed results as they were from GPS
Last night in a slight chop, running the 3/blade SS Ballistic, 14 1/4" 23P, with 1/2 tank of gas, very little gear and just me and my 10 year old daughter, she got up to 55mph on GPS..... it felt good, real good, I have no idea what RPM was as my tach is for OB's and a replacement is ordered and on it's way
I couldn't help but feel the boat could do more with the right prop???? dare I try a 25P?
1999 Interceptor 232 BR, 5.7 GS, Comp Cam
SX Drive, SS 3 Blade Ballistic 14.25 x 23P
Johnny HotFoot
Postby iammarcuse » Sun Sep 22, 2013 7:56 pm
You can dare, but I predict that you are already running at or below the bottom of your rpm range. That motor has a range of 4400-4800. http://www.kirschbaum.at/ki_prop/pdf/2013/rpmchart.pdf If anything you might need to drop a pitch to get your maximum speed. Most cannot run a 23p with that setup. You will know soon enough when you get your new tach. Glad the boat is running well though.
Postby buyfire » Tue Sep 24, 2013 11:06 am
Johnny HotFoot wrote:I couldn't help but feel the boat could do more with the right prop???? dare I try a 25P?
Sure, go for it!!! So long as the 25P prop doesn't have a diameter over 12". :P I'm telling you, you are very close to your max top end for your setup with your current prop. That is a very good prop as long as its condition is good.
Postby Johnny HotFoot » Thu Sep 26, 2013 7:50 pm
New tach is in... :D
test run was awesome, water was near perfect for a speed run
Ballistic SS 3Blade 14 1/4" x 23P
1/2 tank of gas, light load- just me
WOT with drive all the way down showed 4400 RPM AT 55 , trimming her up she spun up to 4800 and gained a tick on GPS speedo 56MPH
so I recon I have a decent prop for top speed, I'm thinking if I were to swap to a different prop it'd need to STAY a 23P and maybe go with different diameter or blade design? even with these tweeks I'm guessing I'd only squeak another 1-2 MPH?
what do you all think?
Johnny HotFoot
Postby iammarcuse » Thu Sep 26, 2013 10:49 pm
Perfect. I wouldn't touch a thing. Congrats!
Postby buyfire » Fri Sep 27, 2013 10:19 am
iammarcuse wrote:Perfect. I wouldn't touch a thing. Congrats!
X2.
Postby m_snow » Sat Sep 28, 2013 10:31 am
Borrow one for test. Don't buy till you know. :flower:
Users browsing this forum: Yahoo [Bot] and 1 guest
