Best Prop for...
Best Prop for...
Postby Johnny HotFoot » Sat Jun 09, 2012 7:11 am
I'm a noob to this forum but not to boats
Forgive me for not searching, but I'd like some responses
Just got a 1999 Interceptor BR, it has a strange prop on it, pointed blades sorta...told it's a ski prop?
but the edges are rough (not perfect) so I'd like to replace it soon...
I want a few suggestions: top speed prop, tube prop, general all-around cruising prop...
350 Volvo Penta, SX drive,
THANKS in advance
Johnny HotFoot
Postby HOT PURSUIT » Sat Jun 09, 2012 9:20 am
ENERTIA is best all around. Best pulling, a 4 blade like Merc Rev 4.
Welcome here :lol:
Postby singintheblue » Sun Jul 01, 2012 6:04 pm
I have the 17P 4 blade REV 4 and love it. As HP says, it's great for pulling and I only lost about 1 mph off the top end.
"Good eatin' size" is a term used only by those who catch small fish.
2000 Caravelle 212BR Interceptor 5.0 Gi Volvo Penta
250 HP, 1.6 ratio, 17P Revolution 4
2006 Toyota 4Runner Limited V-8 270 HP 7200 lb. towing
singintheblue
Postby Johnny HotFoot » Mon Jul 23, 2012 9:48 am
I picked up an alum 14 1/4" 3 blade 19P over the weekend... if it's not a great prop I'll save it as a backup...
Johnny HotFoot
Postby Johnny HotFoot » Tue Jul 24, 2012 8:29 am
Johnny HotFoot wrote:I picked up an alum 14 1/4" 3 blade 19P over the weekend... if it's not a great prop I'll save it as a backup...
pulled the prop off that the previous owner had on, he was an avid skier... it was a SS Ballistic (346034) 3 blade 14 3/8" 21P
It had some work done to it, it wasn't stock, but alas it was chewed up pretty bad with a couple dog ears and had to come off, I'm taking it to a prop shop today to see if it's repairable or just something to hang on a wall???
did a little speed testing last night with the new prop but it was pretty rough out... saw 47 mph (gps) at 5500, which is down from 53 mph with the 21P.... it did jump to plane in under 3 seconds!
I am pretty sure I wanted to go the other way and maybe turn a 23P, maybe higher? I am after all around performance with a lean to top speed...
suggestions??? thanks
Johnny HotFoot
Postby BlewByU » Tue Jul 24, 2012 9:07 am
As stated before, Enertia seems to be what you are looking for. Rev4 for water sports.
2007 Caravelle Interceptor 232SS, 350 Mag, Bravo1
Samson Custom Tower, Perfect Pass, Rev4
BlewByU
Postby Johnny HotFoot » Tue Jul 24, 2012 10:02 am
I like the idea of a 4 blade... is there a cheaper version of the Rev 4?
what size and pitch in the rev 4? again, I'd like a speed prop more than anything, but just don't want a slug to get on plane...
also I need to know the ratio in my SX drive... any one know the ratio in a 1999 SX?
I seem to be able to run right past the 5500rpm mark.... could my rev limiter have been disconnected when the competition cam was stuffed into the volvo GS 350?
Johnny HotFoot
Postby Johnny HotFoot » Tue Jul 24, 2012 10:20 am
Johnny HotFoot wrote:I like the idea of a 4 blade... is there a cheaper version of the Rev 4?
1999 232 BR 350 volvo GS, captains call, SX Drive and all I know beyond that is there's been a competiotion cam shoved in...
she runs like a top but revs to the moon... I'm thinking I need a 4 blade with quite a bit of pitch to it to settle my revs down to 5200-5500???
Johnny HotFoot
Postby Johnny HotFoot » Tue Jul 24, 2012 10:47 am
Is it likely my drive is a 1:60 ratio?
Johnny HotFoot
Postby KCKPM1 » Tue Jul 24, 2012 1:22 pm
What is the fastest GPS non modified 232 350 mag interceptor on this site. How fast and what prop was used to do it. I assume a 21ft interceptor with identical prop and engine would be faster because of less weight. Have 232 and am just curious what you guys have seen.
2002 232 BR Interceptor 350 Mag, Bravo I
Enertia 20P/Rev 4 19P Prop SS
05 GMC Denali XL 6.0L
97 Seadoo 3 seater
KCKPM1
Postby Johnny HotFoot » Tue Jul 24, 2012 3:10 pm
okay...
My local prop shop quoted me 175 to repair the 3 Blade SS Ballistic 14 3/8 x 21P... it's not happening as I am now moving towards a 4 blade 22 P
Johnny HotFoot
Postby Bezdonr57 » Tue Jul 24, 2012 3:38 pm
Johnny,
I have a 22P Merc 5 blade Hi-Five I'll let go cheap. PM me if interested.
2003 Interceptor 212SS Merc 5.0 MPI
2000 Durango 5.9 Magnum 4x4
Bezdonr57
Postby Johnny HotFoot » Tue Jul 24, 2012 6:49 pm
Johnny HotFoot wrote:Is it likely my drive is a 1:60 ratio?
....or is it a 1:43 ????
Johnny HotFoot
Postby buyfire » Wed Jul 25, 2012 10:43 am
Johnny HotFoot wrote:okay...
that's an excellent prop for top end on your setup. but you're right, it's not worth repairing for that price. if you look hard enough, you may find a new ballistic for that price.
that 22P high5 mentioned above may be a good option for you for pulling.
Postby Johnny HotFoot » Wed Jul 25, 2012 12:28 pm
I'm not looking for a pulling prop, I have that in spades with the 3 blade 19P I picked up...
I'm looking for a top speed prop, that will get me on plane in a reasonable amount of time even with a full boat
My local guru thinks a 4 blade 22P is the ticket... but the Rev 4 is only in a 21P and 23P???
what are my options? 3 blade 23P?
I think there's a Bravo 4 blade 22P?
I still need help with this, thanks
Johnny HotFoot
