Rev4 or Bravo1 for 496 powered 232sc
Postby Mercruisin » Thu May 24, 2012 6:48 pm
I'm debating between the Bravo1 or the Rev4 on prop selection. Right now I have a GOD AWFUL Vengeance 21p that can't hold plane for anything as it drops off at about 28mph The thing is I don't know what pitch selection to go with because I can't get good performance figures with my current setup (it has a small chip on one side) The Mercury prop selector is saying a 19p Rev4 with all weights accounted for but I'm leaning towards a 21p.
What do you guys think? Go with the Rev4 at 19p or step up to the Bravo1 at an even greater pitch?
I would love to hear from any big block guys out there or even some 350mag owners as the difference can't be that significant.
I'm not that worried about grabbing every last MPH out of the prop and more concerned with holeshot and lowspeed planing i.e My wife doesn't like to haul ass.
I know I'm new to the forum and I appreciate all the advice.
Mercruisin
Postby KCKPM1 » Thu May 24, 2012 7:40 pm
I have a Enertia 20p on my 350 232 and am very happy with hole shot and top speed. I think its a good all around prop.
2002 232 BR Interceptor 350 Mag, Bravo I
Enertia 20P/Rev 4 19P Prop SS
05 GMC Denali XL 6.0L
97 Seadoo 3 seater
KCKPM1
Postby Flyguy242BR » Thu May 24, 2012 9:56 pm
A 19p is going to be way to small of a pitch, and you are going to HATE it.
You motor is the 375HP and wide open throttle should be 4600-4800. This is the range you need to stay in.
My last boat 242BR, had the 496/375HP and I was running a 23p @ ~ 4700rpms. It would run mid 50's...
I have the 496HO/425HP and have 3 props.
#1. Mirage Plus 3 blade 14 1/2 diameter, 25p
This is my favorite..... With this prop I run about 71-73mph @ ~ 5000 RPM, and planes fairly quick
#2. Mirage Plus 3 blade 14 3/8 diameter, 27P
This prop is my least favorite becuase for every pitch you go up, you loose about 200RPM. This prop I can get about 67-70mph @ ~ 4400-4500 RPM.
#3. Bravo One 4 blade 15 1/4 diameter, 26P.
This prop I get 70-72mph @ 4900 RPM, but this seems to be a faster hole-shot then top end speed.
The test above was done without using trim-tabs, single person, with GPS and about 500 lbs of extra weight (fuel and driver)
I would go with a Mirage Plus 14 1/2 diameter, 23P
I would DEFINITLEY contact the guys at www.bblades.com for recomendations
EX-2006 Caravelle 242 LS
496 MAG Bravo 1, Captain's Call, & other "Optional Features."
Flyguy242BR
Postby Mercruisin » Fri May 25, 2012 8:08 am
Thanks Flyguy that right there is exactly what I needed!
Mercruisin
Postby buyfire » Fri May 25, 2012 11:49 am
Flyguy is correct. my 232/496 runs a 25P 3 blade to 4850 or so RPM. that'd put you in a 23P 4 blade.
Postby Mercruisin » Tue Jun 05, 2012 12:33 pm
I pulled the trigger on a 23p Rev4 so I will let you guys know how it performs once I get it mounted. I'm also having the trim senders replaced this week as it only trims up via the trailer button.
I was super close to going with a 22p Bravo1 but I have heard the huge blade requires some major HP to get it going 400+.
I wonder if Caravelle is going to offer the 502 in their new interceptor?
Mercruisin
Postby clayboy » Tue Jun 05, 2012 5:07 pm
I have a bravo 22p if you decide to go that route, I bought it and decided to stick with the mirage. The bravo 22 helps provide lift in the rear wich in turn helps you plane quicker so they say but I have trim tabs on my boat so don't really need the help planing, but the price was right so I gave it a try. I would probably sell it for a fair price! :lol:
clayboy
Postby Mercruisin » Sun Jun 10, 2012 10:01 am
Gentleman,
I am proud to report that the Rev4 is the best prop I have ever owned. I barely blip the throttle and I'm on plane with 3 adults in the boat. I am seriously considering using the Vengeance as a spare anchor. Thanks for all the suggestions and happy boating!
Mercruisin
Re: Rev4 or Bravo1 for 496 powered 232sc
Postby ghjr » Tue Jul 08, 2014 12:40 pm
Is the Rev4 still a good choice for a 232SC for all around use? I have the Volvo Penta 8.1GI (375hp) and the SX drive with 1.43 gear ratio, would the 23P be a good size for this set up?
2003 Caravelle 232SC Interceptor 8.1 Gi Volvo Penta SX
ghjr
