Dummy Q: tandem trailer brakes (for 206) electric or surge?
Postby msbendts » Fri May 04, 2012 12:04 pm
Ok...ignorant questions...
I'm assuming that the tandem trailers for the (2004-2009) Caravelle 206/207 series boats use a 7-pin electrical connector (vs. 4-pin)...right??
Do these trailers typically have electric brakes or surge brakes (or depends upon the trailer)???
msbendts
Postby twindaddy63 » Fri May 04, 2012 2:34 pm
Most likely your boat trailer, regardless of the trailer manufacturer, is going to be equipped with surge brakes. The 7 pin connector uses the middle pin to lock out the brakes when backing the trailer. The middle pin should be connected to the backup light circuit on the tow vehicle. It will engage a solenoid that inserts a pin behind the accuator and prevents the brakes from engaging
2007 Caravelle 217 LS
1982 Corvette
2004 Titan gas hog
2006 BMW 325Ci
1964 Beautiful wife
"You're gonna need a bigger boat"
If I can't get there by water, I'm not coming.
twindaddy63
Postby Muncie6spd » Fri May 04, 2012 2:38 pm
My 2004 trailer uses the 4 pin connector and surge brakes and all the boat trailers I have ever had and seen use the same.
Since the wheels are totally submerged on a boat trailer during launch and retrieval electric brakes are very rare; I would imagine they would have to be custom ordered.
Thanks...helpful...
Postby msbendts » Fri May 04, 2012 3:07 pm
Ok...helpful...didn't know if there were state regulations around trailer size/weight/axles which dictated surge vs. electronic.
Makes total sense that boat trailers in water doesn't bide well with electronic breaking...
...but is why I asked the Q!
msbendts
Postby twindaddy63 » Fri May 04, 2012 3:15 pm
Actually, my trailer has a 5 pin connector that I convert to the 7 pin for my truck. The 5th pin is the lockout for backing up
1982 Corvette
2004 Titan gas hog
2006 BMW 325Ci
1964 Beautiful wife
twindaddy63
Postby larrym » Sat May 05, 2012 12:38 pm
My '01 with surge brakes is a 4-pin flat (adapted to my 7-pin round truck), the backup lockout is a lever on the side of the hitch head.
2001 Caravelle 212BR Interceptor
8-71 Blown ProStreet '68 Nova SS
2012 40' 5th Wheel 3750FL Big Sky
2009 Chevy Duramax
2009 Nissan Murano
2 Golden Retrievers
Semper Fi
larrym
Postby sdk » Sat May 05, 2012 9:21 pm
twindaddy63 wrote:Actually, my trailer has a 5 pin connector that I convert to the 7 pin for my truck. The 5th pin is the lockout for backing up
That's what I have, also!
Postby Jax » Mon May 07, 2012 5:49 am
It's probably a 5 pin (looks like 4 at a glance). The 5th is the backup light, which locks out the surge brakes so you can back it up.
Lots of flat-to-round connectors are for 4 wire -- avoid those if you need to buy one. Otherwise you will have to use the manual lock-out each time. You have to look close to make sure you are getting a 5 wire to 7 wire adapter.
