Engine Water Temperature
Postby youmansjason01 » Thu Jun 02, 2016 10:00 pm
I have a 2007 Caravelle 237 with the Mercruiser 350 MAG and Bravo 1 outdrive. It's just the standard sea water cooled engine, and has only been in freshwater. Last year, I replaced the impeller just because it had been a few years since it was done. Ever since, the engine has been running slightly hotter than I would like. At idle speed, the gauge read between 160-175. Then, at any other engine speed whether it be 3000 RPM or even an extended run at 4000PM, the gauge moves up to about 185-195. But, it never hits the 200 mark, and as soon as I bring it back to idle, it quickly goes back down to the 160-175 range.
I have replaced the Thermostat twice thinking maybe the first one was defective. It's a Mercruiser 160 degree thermostat. Also, I have replaced the water temperature sender gauge that's on the thermostat housing. Neither of these items had any effect on the operating temperature.
Anyone have a similar boat and engine setup? What temperature does your gauge read when running on plane?
Any suggestions on what I should check next?
Re: Engine Water Temperature
Postby m_snow » Thu Jun 02, 2016 11:57 pm
Disconnect the lower cooling hoses from the low spots on the engine. I've had sand build in those lower hoses and I'm sure it slows circulation.
Give it a try!
