Oil change
Oil change
Postby jkwcfd » Fri Apr 08, 2016 11:23 am
Hey guys I hope everybody's doing good getting ready for the summer On the 232 interceptor with the merc 350 mag motor is there a hose that is like a quick drain for the oil ? If so where is it? I searched forums in this topic but could not find this issue.
John
2007 232 Interceptor
5.7 Merc MAG MPI
2004 Dodge ram 4x4
POPO/MEDIC/ CHAPLAIN
jkwcfd
Re: Oil change
Postby iammarcuse » Fri Apr 08, 2016 1:05 pm
Yup, it is lying under the motor in the bilge. Grope around for it and run it out the drain plug hole in transom. It is a bit of a challenge to get it out the hole as you cannot see anything.
Re: Oil change
Postby rampaage » Fri Apr 08, 2016 2:59 pm
Should be attached to your drain plug, unless the cable has been broke.
2008 237 LS 350MAG Bravo I
2003 Sliverado 1500HD 4X4 Crew Cab
rampaage
Re: Oil change
Postby jkwcfd » Mon Apr 11, 2016 1:13 pm
Awesome help guys I found it no problem!! Thanks!!!!!
John
5.7 Merc MAG MPI
2004 Dodge ram 4x4
jkwcfd
