Question about valve in the bilge
Postby Jaimeson » Mon Feb 11, 2013 3:35 pm
Down in my bilge on one of the plumbing lines, there's a hand valve. Any clue as to what it's for? I can get a pic if needed.
2004 230 Seahawk CC Top Gun outriggers Garmin 740S/18 HD radar Yamaha F225
Jaimeson
Postby shel » Mon Feb 11, 2013 8:35 pm
That should be your seacock valve for your livewell and washdown pump. If it hasn't been turned in a while, it may not want to. Spray some lubricant on it and let it sit a day, then try again.
Postby Jaimeson » Mon Feb 11, 2013 8:56 pm
There you are Shel, am I keepin you busy will the posts I made? LOL
Yea I turned the valve and she was pretty damn stiff. When might this valve need closed??
Jaimeson
Postby shel » Mon Feb 11, 2013 9:20 pm
In a perfect world, never....but you know we don't live in a perfect world! If your hoses to the washdown pump or livewell pump started leaking, you would need to be able to turn if off. If memory serves me right, it only goes from straight up to 1/4 turn or maybe side to side 180 degrees (1/2 turn). I usually spray it with lubricant, then open/shut the handle 6 or 8 times, every six months to keep it from coroding. Actually I'm glad you posted this because I last sprayed mine last summer.
Postby Jaimeson » Mon Feb 11, 2013 10:12 pm
Thanks for the info man. Yea it turns one half a turn. Do you use WD40 or something else?
Jaimeson
Postby shel » Mon Feb 11, 2013 11:11 pm
WD40 is okay. I've used that, CRC and several others I can't remember the names. Really, any good spray lubricant will work.
Postby Jaimeson » Tue Feb 12, 2013 2:05 pm
Think I'm gonna hit it with some PB blaster, that stuff always works good.
Jaimeson
Users browsing this forum: No registered users and 3 guests
