Bueller...Bueller
Bueller...Bueller
Postby dancaravelle267 » Sat Sep 19, 2015 1:58 pm
Who is still on the forum?
Re: Bueller...Bueller
Postby AndrewT » Sun Sep 20, 2015 5:11 pm
I still visit it regularly but not much happening here.I'm waiting for the weather here in OZ to warm up.Only had one or two warm days here to boat but too busy on those days to take advantage of them.I've done the trailer wheel bearings,oil and filters changed on the motor and oil in the outdrive replaced.Still due to clean and polish.There has been a lack of posts with members outings this year, and it's not going to improve as you guys are going into your fall and winter.
Postby dancaravelle267 » Sun Sep 20, 2015 9:57 pm
I have not been on here as much this summer but we have not been on the lakes much either. The ramps just opened back up about three weeks ago. In May we had a ton of rain. Our two closest lakes were up around 16' high. The larger one to our north was up 26'! Needless to say, this is the least amount of time I have put on a boat in years. I did put new carpet from Corinthian in the boat this summer....looks nice!
Postby rward182 » Mon Sep 21, 2015 7:59 am
I still visit the site, but like Dan, the lakes were up too high to get onto, so I only made it out 3 times all summer.
Postby AndrewT » Mon Sep 21, 2015 8:14 am
dancaravelle267 wrote:I have not been on here as much this summer but we have not been on the lakes much either. The ramps just opened back up about three weeks ago. In May we had a ton of rain. Our two closest lakes were up around 16' high. The larger one to our north was up 26'! Needless to say, this is the least amount of time I have put on a boat in years. I did put new carpet from Corinthian in the boat this summer....looks nice!
Please post some pics of the new carpet.
Postby BigB » Mon Sep 21, 2015 3:18 pm
Still here, just has been a crazy summer.
2007 Interceptor 232 496ci Bravo 3
BigB
Postby HOT PURSUIT » Thu Oct 22, 2015 5:17 pm
Wow! Been a bit for me as well! :(
Postby rickg » Fri Oct 23, 2015 8:29 pm
I have been intending to get on here and post something. Living northwest of Fort Worth, we were high and dry up until May. The lake was about 80 feet from my boathouse. In late February our lake was 11 feet low. Anything over 4.5 low and i cannot lower the boat. By mid-July our lake was 3 feet over full and the lake was closed. It was raining it seemed like every weekend so we couldn't get out. I think one weekend in late June when lake was full but not closed, I was able to get out, for a few minutes. Had our kids and grandkids onboard. After boat was warmed up and we started down the lake, I heard something like a belt hitting against a pulley. Raised the bonnet and sure enough the belt was off. Looking further, the pulley was extended out from the water pump housing. So i jiggled it a little and it fell in the bilge, pulley hooked to the shaft. I only had 28 hours on a new impeller that I had put in late in 2013. Boat sat for 1.5 years for the most part. I think the water pump shaft was rusted to the two bearings in the housing and when i hit the rpms, it bound up and spun the shaft, bearings and pulley out, all as one unit. at least i think that is what happened. fortunately my neighbor was on his new boat close by and towed us home.
so the next weekend or two, the lake was closed anyway while i replaced the impeller again. did it myself so it took awhile. Second time i have done this so I have some lessons learned I will try to share. First time i did it i didn't take out the compartment under the rear seat. this time i did and it took less time and was a little easier. Anyway, was able to put about 40 - 45 hours on it this summer. My wife wouldn't let us do anything but go out on the boat every Saturday and Sunday pretty much. Will post more later. Gotta go eat some Mexican food. Rick
2008 Caravelle 237 LS "Lil Bit Mo"
350 MPI, Bravo III, switchable exhaust, sub-woofer, amp, dual batteries, docking lights
rickg
Postby HOT PURSUIT » Fri Oct 23, 2015 11:43 pm
Hey dancaravelle267. I would love to see pics of the new carpet as well.
Postby sdk » Sun Nov 01, 2015 6:12 pm
I've been on Modern Camaro and Corvette Forum a lot lately.
Hubby and I ran the Interceptor last weekend. That will probably be it for 2015. Winterization is next.
I hope all are well!! 8)
Postby egore1 » Sun Nov 08, 2015 10:26 am
Admittedly, it's been more than a few weeks since I've been on. I still come here to see if anyone else posts any helpful hints or has a question; but then the boss comes into my office & I have to shut down!
We've used the boat a good deal over the summer and, whatever problems I've had, I just had the mechanic at the marina take care of. I brought the boat home October 29th after having it winterized. The last time I took her out, I spent two or three hours parked at a beach with 2000 grit wet/dry and worked on the oxidation of the gelcoat. During the off season, I'll go over it again and then buff and wax.
Then before next season begins, we'll get the cushions in the bow area repaired and recovered.
Right now, the cat uses it as a perch to scan for prey! Good a use as any, I guess.
1995 Caravelle 1900SE
4.3L Mercruiser
"Life is better on a boat."
egore1
Occupation: Video production
Postby buyfire » Tue Nov 10, 2015 11:50 am
egore1 wrote:Right now, the cat uses it as a perch to scan for prey! Good a use as any, I guess.
That should be a good bird crap deterrent.
Postby pilotmike » Wed Nov 11, 2015 12:03 am
Here, listening, upgrades coming, but after the holidays. Carpet, vinyl, sound system, Caravelle not much help so far with questions, no response from two e-mails, but I still have some time.
Mike V.
2001 232
350 mpi
Hot Pink, Hot Yellow, and Jade
Shes Loud and Proud
pilotmike
Postby stever » Thu Nov 12, 2015 2:19 am
Hi there. I am a new boat owner just bought a Caravelle a couple months ago. Tried to join then too but was just approved the other day. I hope to learn from the veterans here. Thanks, Stever
2003 232SC 496
stever
Postby AndrewT » Mon Nov 16, 2015 8:43 am
Welcome to the forum.Please post some photos of your boat.
love them 232's with a 496 :D
Users browsing this forum: Bing [Bot] and 2 guests
